Discussion topic: MY PRINTER IS CONNECTED BUT SAYING ITS OFFLINE
Message posted on 15 Jun 2021 06:34 PM
My printer wont print it is online and ready , but says its off line do i need some sort of firm update n the box. please advise was working great with the old box.
please advise as i need it for work.
thanks
Message posted on 15 Jun 2021 06:43 PM
Re: MY PRINTER IS CONNECTED BUT SAYING ITS OFFLINE
You had the router on the left-hand side in the link below is this what you are talking about?
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/which-sky-hub-do-you-have-no
Message posted on 16 Aug 2021 05:43 PM
I've got a similar problem. I have an Epson 3550 which worked perfectly, wirelessly printing from mobile phone, tablet and PC. Since upgrading to SkyQ I either cannot print at all, in the case of my mobile, or a PC takes several minutes to hours to empty its spooler.
I'm ex IT so have done all the obvious tests. It's almost as of there is an internal firewall stopping a spool command from seeing or waking up the printer.
Message posted on 16 Aug 2021 06:13 PM
After my last post I had a think and came to the conclusion the SkyQ box was probably at fault. Physically unplugged it and my problem went away, plugged it back in and the problem returned. Whatever protocol or internal routing SkyQ is now using to talk to the router is interfering with printing (and I suspect a few years their issues like buggering on my phone) since they turned the box into a WiFi repeater.
Message posted on 16 Aug 2021 06:37 PM - last edited: 16 Aug 2021 06:39 PM
@Forestwalker I believe it is something to do with the Sky Q mesh, as it's known to cause issues of devices not appearing on a network with things such as multi room audio equipment too like Sonos et al, when they connect to the Q boxes as opposed to the main router, which is well documented. I bet if you tried it with the Sky boxes switched off and only the router on that it would print perfectly ok.
I bet your printer is connecting the WiFi of a Q box and not the main router.
I'm not suggesting the solution is to unplug the Sky boxes every time you print, but that's most likely where the issue stands. Is it feasible to cable the Sky Q boxes so you could disable the mesh, assuming you don't use the boxes to spread WiFi around the property?
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
Message posted on 16 Aug 2021 07:10 PM
JPR, nope, printer is wirelessly attached to the router whilst SkyQ is in another part of the house with a Devolo WiFi/network port extender. My house has 2' thick slate walls and the TV, Amp, Sky box are outside the main house in a "newer" extension.
Turning the Sky box off and the problem is no more (so at least I can print). I might see if I can turn off the Sky mesh as I don't need it especially as it is causing problems.
Message posted on 16 Aug 2021 08:15 PM
@Forestwalker Dont forget unless the Sky Q boxes are cabled, if you turn the mesh off they will all break, as they create there own mesh for streaming between boxes.
Message posted on 17 Aug 2021 11:06 AM
Thanks all, up and running again had to delete and connect to new sky box.
