Discussion topic: Lip Sync Issue
This message was authored by Sbos This message was authored by: Sbos
Lip Sync Issue
On two occasions recently I have had lip sync issues which have been resolved by unplugging my Sky Q box waiting then plugging in again. Is this something others have experienced and is it an ongoing issue? If the unplugging of my SkyQ box resolves the issue, as it does, would this mean it's a Sky issue rather than a TV issue?
Locked
This message was authored by Doc5907 This message was authored by: Doc5907
Re: Lip Sync Issue
@Sbos  based on a box reset solving the issue, it would suggest it's a Q box issue. If it continues, suggest you call Sky who may send an engineer out who possibly might swap out the sky Q box.
Sky Q 1TB UHD
LG TV
Sky Mobile
BT Broadband
This message was authored by Quoman7 This message was authored by: Quoman7
Re: Lip Sync Issue
Hi @Sbos  A reboot of the SKYQ box usually solves minor problems, issues with lip sync can be down to audio settings or on occasions HDMI connection to the TV.
I wouldn't worry if your lip sync issues have now been eliminated with the box reboot.
Locked
