6
Discussion topic: ENTER PIN
This message was authored by paladin100 This message was authored by: paladin100
ENTER PIN
i have programmes on planner when i try to open them it asks for my pin.
it says the last 4 numbers  of the card you use to pay your bill or the last 4 numbers on your bill.
i have tried both these and they don't work .also most times it will miss a number out.
if i put in 1111 it will put in 11then it won't let me put any other number in.after a few seconds it says incorrect pin.
can anyone help please.
paladin100
This message was authored by paladin100 This message was authored by: paladin100 Answer
Re: ENTER PIN
thanks to all problem solved i had to ring sky as nothing worked . they reset my pin. now all is fine.
  thanks again. to all of you.
Locked
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: ENTER PIN
@paladin100 Pin's are normally to last 4 numbers of your viewing card. You can change it to something more memorable.
▪️I AM NOT A SKY EMPLOYEE ▪️
This message was authored by Invisiblename This message was authored by: Invisiblename
Re: ENTER PIN
As already stated, it is normally the last 4 of your viewing card, and entering 1111 without changing the default PIN will not work.
I am just another Sky customer!
This message was authored by PeteRG41 This message was authored by: PeteRG41
Re: ENTER PIN
How to change yout Sky Q PIN code:
Your Sky PIN | Sky Help | Sky.com
____
Pete.
paladin100
Re: ENTER PIN
Moning , i tried all of the things you suggested, nothing worked. so i rang sky and he reset my pin. now everything is ok.
thanks .
paladin100
Re: ENTER PIN
Re: ENTER PIN
@paladin100  Great news! Recommend that you follow the guide above & change your PIN to a simple number eg 1111 to make entering it less of a chore
Locked
