5
Discussion topic: Internet speed
This message was authored by Abbey13 This message was authored by: Abbey13
Internet speed
One of the worst internet, 2 bedrooms flat with 4 connected advice. The Sky speed testing is showing working great but 3 different speed meter proving not enough!!! Very annoying
This message was authored by JPR007 This message was authored by: JPR007 Answer
Re: Internet speed
@Abbey13 Flats are usually the most difficult when it comes to WiFi as there are usually many other networks in close vicinity.
First step would be to separate the WiFi bands and ensure your phones and tablets are using the 5GHz WiFi not 2.4GHz, which they are probably most likely using at the moment and it's probably very crowded and interference ridden.
The Sky test doesn't test the connection to your end device, as @Highlinder stated, it checks the connection to your hub/router from the street cabinet. That is the speed you are paying Sky for, and is what they are contractually obliged by.
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
Locked
Re: Internet speed
@Abbey13 How are you measuring the speed through the other speed testers, as the speed Sky is showing you is to the router and not to a device.
Re: Internet speed
Abbey13
Re: Internet speed
@Highlinder  you are computer tech and this is the best answer what you can give. Thanks 👍
Abbey13
Re: Internet speed
@JPR007 Thanks for your advice will be helpful
Re: Internet speed
@Abbey13In simple terms yes, as wanted to find out who you had gone about measuring the speed to your flat. As @JPR007  pointed out the speed to the router is what Sky are interested in and not to any of your devices.
Locked
