Discussion topic: How to set up magic eye to sky Q
This message was authored by Muze This message was authored by: Muze
We have just had new sky Q installed. How do link up my magic eye from another tv
Locked
Re: How to set up magic eye to sky Q
You can't use a magic eye with Sky Q I'm afraid. If you want Sky in another room you need to order yourself a Sky Q mini and if you haven't already get a multiscreen sub added to your account.
Muze
Thanks. Do you have to have a sky Q mini for each room that you want sky in??
Yes you do. You can have up to 4 but will only be able to watch 2 at the same time.
Muze
Oh right I see and are you charged a multiroom sub for each individual mini. Or is one multiroom sub charge for up to 4?? Thanks
This message was authored by Mark39 This message was authored by: Mark39
Yes.
The alternative might be to use an HD modulator such as this to distribute the output from your main Sky Q box via your existing coax cabling. You would need to do some research, and it's not a setup that Sky would provide support for.
One subscription covers all minis @Muze
You can have up to four installed but can only watch two simultaneously in conjunction with the main Q box.
With the original 1 TB non UHD box you can only watch one mini at a time
Muze
Thank you. For your help
This message was authored by Raider999 This message was authored by: Raider999
@Muze Mini boxes are easy to move so if you only ever want to watch sky in one other room at a time I might be tempted to do that. You will still need the multi room sub but will save you on the ' £50 Admin fee per minibox'.
Muze
That's great thanks
Locked
