This discussion topic is read only Discussion topic: How do I add my Soundbar to Sky Q Remote
This message was authored by: StewieGriffinsDun
Hi
I have a Majority Snowdon 2 soundbar. However I can't seem to control the volume using Sky Q remote via optical cable. I have the IR code is there anyway to input it?
I can control it using line out however that is using the TV volume.
It's just frustrating having to use 2 remotes .
Locked
Re: How do I add my Soundbar to Sky Q Remote
@StewieGriffinsDun wrote:
Hi
Hi @StewieGriffinsDun
Q Bluetooth remotes with Voice control use Brand and model and not codes.
If your Soundbar is not listed check Other Brands.
Run the setup again by pressing 1 &3 together on the remote and see if Other Brands is listed.
This message was authored by: Chappers3000
I have the same product and the brand / model does not appear in the supported products list. Under Other Brands it jus says it is not compatible, but I have not yet discovered the 4 digit universal remote control code, do you have this code? have you tried setting it under settings > Setup > Remote Control > Sky Q Remote > Control a speaker system > I know it.
then press and hold 1 and 3 on the sky remote together for 2 seconds > Enter the 4 digit code for the soundbar > try changing the volume.
If that does not work then I do not think there is any chance of getting it to work.
Note, on my other Sky Q mini box I managed to connect a Megacra Soundbar to it and Megacra did appear in the list of supported brands, but on my other sky Q mini box it does not appear.
This message was authored by: robert+done
Re: How do I add my K2 Soundbar to Sky Q Remote
Have just set up the sky q remote from new by pressing 1 & 3 together and it worked great. I am using a HDMI ARC connection. If that helps.
This message was authored by: Nellieandtom
I struggled with my small JVC and Samsung tv. Eventually I changed from optical to HDMI -ARC and looked up the code for my Sky Q remote. Once I changed my output  from optical to HDMI on my tv in settings I can now use my Sky Q remote for both.
Locked
