Discussion topic: Fault codes
Message posted on 18 May 2021 04:05 PM
Fault codes
On certain recordings with Sky+ hd l get the error code failed recording Technical fault - 10 (28). Can anybody help?
Message posted on 18 May 2021 04:11 PM
Re: Fault codes
To my knowledge, TF10 faults are usually Planner related. The suffix 28 suggests it's a signal problem. What is the text associated with the TF reference?
Message posted on 18 May 2021 04:13 PM
Re: Fault codes
There is no other text with the message.
Message posted on 18 May 2021 04:20 PM
Re: Fault codes
I don't think it's possible to be any more specific in that case.
