Discussion topic: Damaged Satellite
Message posted on 16 May 2021 08:47 AM
Damaged Satellite
Our TV was damaged in a storm last week and we've had to replace it. It now looks like the same has happened to the Sky Box and/or satellite dish. The box switches on and seem to be recording things we had set up but the tv cannot find the box.
Message posted on 16 May 2021 09:10 AM
Re: Damaged Satellite
First and obvious question is have you set the TV input to the correct HDMI to which the Sky box is connected?
Message posted on 16 May 2021 10:24 AM
Hi @Kuga+Man
Try setting the Q box to standard resolution.
You can do this with the Q box on with green led press
Home 1 0 8 0 Home
on the Q remote control.
This will reset the Q box to 1080i resolution
Message posted on 18 May 2021 06:36 AM
We don't have a Q box. We've managed to contact Sky and they are coming out to check the dish and upgrade the box. Thank you.
Message posted on 18 May 2021 08:03 AM
Odd that we should jump to assumptions given this forum is for Sky Q. 🤔
Message posted on 18 May 2021 03:04 PM
Apologies- should have read info more carefully.
