Discussion topic: Extremely slow downloads
Message posted on 28 Mar 2022 09:30 PM
I've tried everything I can, and one programme of 45 minutes took 4 hours to download......
Message posted on 28 Mar 2022 09:32 PM
Re: Extremely slow downloads
Try a Reset Settings in the hidden menu it may help
Press 1 & 3 together on the remote and follow onscreen instructions to re pair.
