18
This discussion topic is read only This discussion topic has been answered Discussion topic: Edited scenes
This message was authored by: Lisaj47
Edited scenes
I'm watching Grimm on demand. These are PIN protected programmes. I was wondering why the slightly more gruesome scenes were edited out. I could understand if it was general viewing, but surely if a programming is PIN protected the full episode should be included. It does detract from the story line.
Re: Edited scenes
@Lisaj47
The Viewer Relations team are Sky are the people to ask about this, they can be contacted via thie email address - [email protected]
Locked
Re: Edited scenes
@Lisaj47
This message was authored by: ozsat
Re: Edited scenes
I agree that if a programme is PIN protected then they should not be editing it further - but it keeps someone in a job 😉
At what time was the programme as I could understand some mild edits if the original is an 18 show but they are airing a 15 version?
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
This message was authored by: nolte
Re: Edited scenes
Someone else raised this question
Under ofcom rules, even with pin protection a programme rated 18 may not be suitable for broadcast before 9pm so the edits for broadcast before 9pm (is that 6pm) is to bring them under ofcom rules
ROI sky Q Customer.
Re: Edited scenes
That why I asked what time the programme was as the original post was late at night.
Broadcasters seem to enjoy editing bits out of programmes - especially UKTV - and sometimes there is little logic when looking at missing bits and bits left in.
Avatar for Lisaj47
Re: Edited scenes
It doesn't seem to matter what time I watch the programme. It's always edited. I wonder if it is related to the time the show was originally aired? Just very annoying
This message was authored by: LGUser
Re: Edited scenes
@Lisaj47Are the versions available from Catch-Up edited?
Re: Edited scenes
If that's the version provided to distributors by the rights-owner, then that's the one which is going to be shown.  A distributor can't arbitrarily restore 'missing' sections.
In some cases, two versions circulate forever, and sometimes get mixed up: the legendary example is the 'television' version of 'Goodfellas' edited for language by Scorsese himself that has on occasion inadvertently been replaced by the theatrical cut.
This message was authored by: JonD1492
Re: Edited scenes
If it's of any help:  GRIMM is broadcast at 6pm.  The versions being broadcast right now, are edited for their timeslot.  The PIN-locking is because the show is very edgy, even in its cut version, and many of the episodes are 15 rated by the BBFC.  The PIN-locking is to alert parents that the show may not be suitable for youngsters, even its cut form.
It is NOT the same as (for example) Sky Atlantic, who broadcast uncut versions of some of their shows during daytime hours, like THE SOPRANOS, or OZ, etc, which are PIN-locked for everyone.
This message was authored by: Timelord2018
Re: Edited scenes
Are the scenes edited on the Peacock version of Grimm ?
Re: Edited scenes
1) If a programme is PIN-protected, it's purely to make parents aware that there's something in the show that means it isn't suitable for under-18's to watch.  It does NOT, however, mean that the PIN-protected show is uncut/unedited.
2) Not all PIN-protected shows are complete and uncut.  Every channel uses the PIN-protection system differently, based on the programme being protected and the likely/intended audience.  Some channels PIN-protect content, that is uncut/unedited (like Sky Atlantic).  Some PIN-protect only adult shows that need it.  And others PIN-protect based on a programme-by-programme basis, regardless of the channel's broadcast time slots.
3) As mentioned in another thread on this same topic. my understanding is that GRIMM is mostly a 15 certificate show, with a few that have been given 18's for very gory violence.  When originally broadcast, it was put in a 9pm/10pm timeslot, as it was clearly unsuitable for under-15's/under-18's.
In later times, it's been broadcast with some trims/edits at 8pm, but there is also a more family-friendly edit, that is being shown at 6pm.  This removes almost all of the gore, a lot of the strongest violence, and tones down the shock/scare factor substantially, to render it suitable for an early-evening slot.  However, that doesn't mean the show is being aimed at, or intended to be viewed, by children.
In this case, Sky Max (the channel it's being aired on now) have decided that they want to maximise the viewers watching it, in the same way the BBC and Channel 4 tried to do with similar shows to GRIMM, like BUFFY THE VAMPIRE SLAYER and ANGEL.  But, just as occured with both of those shows as well, edits were needed to make them suitable for early-evenings.
Such is the case with GRIMM.
This is clearly an editorial choice by Sky Max, and because they are aiming this at teens/young adults under 18, they've decided that only the cut/as-broadcast versions are going to be put on the Catch-Up service, so that if kids do see the show, the edited versions won't contain anything that should cause upset, as the show is PIN-protected.
Again, this is a channel decision.  Just as with QUANTUM LEAP, GRIMM is easily available to buy on DVD and Blu-Ray, for those who want to see it uncut and as originally meant to be viewed.
Viewers need to understand, that just because a show is being shown early (pre-Watershed) and PIN-protected, doesn't mean that a channel is going to make the uncut versions available.  You may not like this.  You may think it's silly, or pointless.  But this is how the channel has chosen to air this show, right now.
Should anyone wish to complain about this, then the best bet, is to get in touch with Sky directly, either via e-mail or telephone, and put your complaint to the channel itself - which is what I do.  It's the best solution.  If the channel gets sufficient complaints, they may change things.  (Channels do listen, in general, to what viewers say.)
I hope that helps.
Re: Edited scenes
Grimm will be getting a repeat showing on Syfy from 4th of January at 9pm , will be interesting to see if those episodes are cut by Sky or not.
Re: Edited scenes
@Timelord2018
For a broadcast after 21:00 one would hope not, but then it depends on the channel both having access to an uncut version and knowing enough about the difference to care.
There's a 'TV edit' of the classic film Callan (1974) that sometimes gets broadcast after the watershed which manages to remove the crucial scene that the entire film is leading up to and renders the whole thing almost entirely pointless, which is rather a shame as it is up there with Get Carter (1971) as a piece of British noir.
Re: Edited scenes
@TimmyBGood wrote:
@Timelord2018
There's an edited version of the movie Hilander that basically spoils the movie.
This message was authored by: rscott
Re: Edited scenes
@LGUser wrote:
@TimmyBGood wrote:
@Timelord2018
Must be heavily edited if they've even cut 2 characters from the film's title 😀
Locked
