3
This discussion topic is read only This discussion topic has been answered Discussion topic: Deco Product and Company VPN
This message was authored by: triford
Hi,
I decided to add a Deco x60 to my house network but having some issues. Initially I used the router mode but have now gone to AP-Mode as my wife WIFI was dropping on calls. I've been connected via a cable on my work laptop but today needed to use the WIFI. But my VPN just keeps on dropping out.
Looking at the CISCO VPN Software it refers to Proxy being enabled with Always On.
My Sky Router has all wirless settings disabled as per other Deco Posts. (Wirless AP / SSID).
What can i do to resolve. Do I assign an IP on the Sky DHCP ?
This message was authored by: jamesn123 Answer
Re: Deco Product and Company VPN
@triford
Sounds to me an issue with the Deco system maybe unless you can confirm the issues are all still present when using the Sky hub only?
I am NOT a Sky Employee
Locked
@triford
Is the Deco system definitely in AP mode? It shouldnt be giving out IPs and all your wired devices should still be connected to the Sky hub not the Deco system
Avatar for triford
Level 2 icon
@jamesn123 yes on AP Mode. Disabled Fast Roaming and Beamforming too.
Decided to use WiFI as couldn't access my cable. Think my wife is having issues with here teams calls now too. Strange as fast speed test reports 250mb.
@triford
Locked
