Discussion topic: Connecting a device via ethernet cable
Message posted on 09 Nov 2021 07:31 AM
Hi,
I need to connect a device to my hub via ethernet cable, the device can't be connected wirelessly. However, my hub is too far away from where the device needs to be located in the house. I notice there is an ethernet port on the back of the Sky Q box. Can this port be used to connected a device that requires internet, or is it only to connect the Q box to the hub via ethernet rather than wirelessly?
Thanks,
Anthony
Message posted on 09 Nov 2021 07:38 AM
Re: Connecting a device via ethernet cable
@ant550lag yes the device can be connected to the ethernet port on your Q box but speeds will be limited to the wifi speed that box receives and when the TV box is in use the connection speed will be reduced yet further.
A better solution if the device needs a lot of bandwidth like a PC is to buy a powerline kit which uses your mains wiiring to carrybthecdata.
Message posted on 09 Nov 2021 08:16 AM
Thanks Chris.
I don't think it needs a lot of bandwidth. Its a hub for a smart cat flap (Sureflap hub)
As long as its connected to the internet I think it will be fine.
I just wanted to check the port on the Sky Q box could be used in that way, as a relay for the internet connection.
Message posted on 09 Nov 2021 12:03 PM
@ant550lag err no thst should be fine for bandwidth. The Q boxes can act as a wifi to ethernet bridge.
Not thought of connecting my cat door to the internet bit worried what the owner might order not keen on bulk rodent deliveries.😀
Message posted on 09 Nov 2021 02:19 PM
Well you learn something new everyday ....
I always assumed the LAN port on the Sky box was purely to give the Sky box a wired internet connection rather than wireless one.
Message posted on 09 Nov 2021 03:06 PM
@smudgester wrote:I always assumed the LAN port on the Sky box was purely to give the Sky box a wired internet connection rather than wireless one.
@smudgester That is the primary reason yes, but it can also be used backwards as you've now discovered 😂
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
