7
This discussion topic is read only This discussion topic has been answered Discussion topic: Compatibility of TV with Q mini box
This message was authored by: Sheppardess
Hello, can anyone tell me whether the 32" Samsung QLED Frame TV is compatible with the sky q mini box? There are conflicting views around. Thanks.
This message was authored by: nigea99 Answer
Re: Compatibility of TV with Q mini box
Locked
hi @Sheppardess the mini boxes don;t require very high spec TVs so I would expect them to be compatible with most TVs.
I am afraid I don't know specifically - perhaps you quote a model number so we can look up specifications etc.
I am guessing being a 32" TV it might only be able to use the lower resolutions as many are not Full HD but HD ready
Are you able to give any info on the reports of incompatibility - i.e. what problems people have had ?
Edit SKy Minis actually have an analogue out (composite video)  feed should your TV support that
Avatar for Sheppardess
Thanks -the model number I'm looking at is QE32LS03TC. It has two hdmi ports, no Ethernet connection, and requires a Samsung mini connect box. But with the two hdmi ports I thought that would be sufficient? The problems are a bit non-specific.
And PS @nigea99 thanks again forgot to tag you - it's full HD
@Sheppardess if it's full HD then there should be no problem with it
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
HI @Sheppardess maybe this discussion shed some light on the use of the connect box:
https://helpforum.sky.com/t5/Sky-Q/Sky-Q-2TB-box-with-Samsung-One-Connect-problems/td-p/3249387
Thanks @nigea99 and @Laing1
That's helpful, looks as if the connect box might be the issue. Solution, as usual, to switch off and on again! I may rethink the new tv. Thanks again.
hi @Sheppardess difficult to tell how awkward.
At least now there are a few Full HD 32" Tvs around - don't be tempted to go for a HD ready one
When I bought my 32" to replace my bedroom TV just before the last Olympics there were only a couple (if that ) Full HD 32" Tvs at that time - I am so glad I held out for the Full HD Sony I got, as 5 years on I use it very successfully with a SKY mini and a Firestick (Not sure if Sony currently do a full HD in that size though)
Locked
