Discussion topic: Channel lists and favourites
Message posted on 10 May 2022 08:57 PM
Hi SKY Q experts!
Got set up today with SKY for the first time. I see how to mark channels as favourites, but isn't there a way to have those favourites in one list where I can set them in a logical sequence e.g BBC1, BBC2, ITV1, ITV2, etc then have the sports together, documentaries etc etc. Get the drift? Who wants to scroll trough dozens to find the one you want there and then.
Cheers.
Message posted on 10 May 2022 09:00 PM
Re: Channel lists and favourites
@shoemanpete If you have marked them as favourites and savd them then you can access them in the favourites list. https://www.sky.com/help/articles/using-favourites-on-sky-q
Message posted on 10 May 2022 09:16 PM
@shoemanpeteThis is how it is supposed to work but it is not working for me either.
"Go to the TV Guide, followed by Favourites and then select Setup favourites. You’ll be offered a list of channels, based on what you’ve watched before. From there you can choose to Change list or Save list.
To change your list, scroll to the bottom of your Favourites and select Manage favourites."
Message posted on 10 May 2022 09:33 PM - last edited: 10 May 2022 09:34 PM
Just out of interest @bob1234 which bit isn't working for you ?
I get Manage Favourites (as I already have set mine) then when I Save List I can select & move them around OK & then end with Save & Finish - all working for me
Message posted on 10 May 2022 09:52 PM
@nigea99 wrote:
@bob1234 wrote:@shoemanpeteThis is how it is supposed to work but it is not working for me either.
@nigea99 I just did not understand the instructions, having set up favourites again I never guessed that I would have to save again before I could move the channels around. Sky's instructions are less than clear. It looks as though the options are "you can choose to Change list or Save list." rather than having to save the list first. @tarbat put me right.
Message posted on 10 May 2022 09:55 PM
I just watched the video posted earlier and it shows exactly what I want, to be able to move the channel up to a different position i.e in the order I want them. Thanks.
