Discussion topic: Cable
Message posted on 28 Mar 2022 08:33 PM
Hi we’re having SkyQ & Broadband installed, my question is can I use my existing Virgin Media RG6 cable that’s layed under my flooring?also will I have lay new cable for my router?
Message posted on 28 Mar 2022 08:43 PM
( @nigea99 I've put this back in Q as it refers to Q install)
Hi @contact400
Q needs two cables and if you have two and they are in a suitable condition then they can be used.
However they need to go continuously from Q box to Dish position with enough slack foe use at each end
Hi @contact400
Message posted on 28 Mar 2022 08:46 PM
Re: Cable
Hi @contact400
Apologies both - picked up on the Router question - I guess that is the problem when covering 2 questions that have 2 separate boards
Re: Cable
Message posted on 28 Mar 2022 08:48 PM
Re: Cable
This is what virgin currently use, will this be suitable. Cheers in advance
Message posted on 28 Mar 2022 08:51 PM
Re: Cable
Hi @contact400
Doubtful as you need two cables from your Q box position to the satellite dish position
Message posted on 28 Mar 2022 08:53 PM
Re: Cable
Cheers mate
Message posted on 28 Mar 2022 10:01 PM
Re: Cable
If you take 2 in from the dish and join to the other 2 (presuming they go to box location) you'll be fine
Message posted on 28 Mar 2022 10:06 PM
Re: Cable
They connect to another splitter. There's only one RG6 cable
Message posted on 28 Mar 2022 10:07 PM
Re: Cable
Unfortunately you need 2 - one for each polorisation (V/H)
