The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
07 Aug 2021 06:21 PM
Hello,
I lose signal after 10 meters in my home. This is normal? Probably I need something to have stronger signal ect. Wifi extender. How much I need pay for this? I have Full fibre now.
07 Aug 2021 06:26 PM
The sky mesh booster boxes come with an upgrade to broadband boost when you don't get at least 3Mbps in everyroom. Cost £5 extra per month
Posted by a Superuser, not a Sky employee. Find out more@Mateusz+P Your broadband isn't losing signal, it's the wifi from you router that is the problem https://www.sky.com/help/diagnostics/bb-speed/how-to-improve-your-broadband-speed-all
Wifi & Broadband are 2 different things.
08 Aug 2021 04:08 AM
@Mateusz+P wrote:Hello,
08 Aug 2021 06:33 AM
Posted by a Superuser, not a Sky employee. Find out more@Mateusz+P wifi outside your home is never going to be easy as the external walls of your home will reduce signal strength placing the hub near a window can help.. The 2.4GHz band has longer range than the 5GHz band so you can try separating the wifi bands see Split Sky WiFi bands
