This discussion topic is read only Discussion topic: Broadband Problems 19/9
Locked
This message was authored by: Gemhealy
Re: Voice light staying orange
I can't access the MySky app either because it says it's under maintenance
This message was authored by: EhsanArain
Re: Is everyone else’s sky down?
Any real reason,why it's not working?
This message was authored by: gurch1
mine is down and im in SE London
This message was authored by: Buzz
Re: Broadband update from sky?
Where please? It's not on in London.
This message was authored by: Nipper8
I'm in South Wales and my Internet has been down for a few hours now. All green lights are on but no Internet. Also there systems are down apparently due to maintenence work 😡
This message was authored by: Annieimai
No internet in Derby as well
This message was authored by: rhett
Re: My broadband is not working
I'm a VIP Diamond mug!! Work that one out !! Time to find someone that can provide a robust service. Sky is like your car insurance company robbing loyal customers in favour of new ones who on paper increase market share. Sky and.other companies rely on your loyalty but give noting back!! Shop around !!
This message was authored by: Tempo
Same problem here in LL28.
Not had internet since around 10:15pm.
Have tried everything to get it working, just isn't doing anything! This is not acceptable at all.
This message was authored by: carol63
Won't be getting Any sort of refund though ?
This message was authored by: Minniej80
Re: Broadband down
I'm in Belfast and ours is still down at 1:11am.  Tomorrow will be fun trying to complete college assignments without broadband if it isn't up again.
Re: DNS server issue on multiple devices
DNS is a directory service "out there" on the internet that takes what you type in a browser like www.sky.com and tells your pc what the IP address of that website is so it can connect to it.
when any device connects to a network, typically at home that being managed by your router, it automatically gets told what DNS server to use. Which has an IP address of its own. No name as such because what would you use to lookup the address of the thing you need to use for looking up addresses? 🙂
Normally this DNS address setting is actually also your router's local IP address within your network, but it doesn't really run a DNS server, it passes the lookups on to a real one that your ISP is running (which it got told about when it connected to the internet)
The important thing is - you can manually override this setting if it's going wrong and it's easier to do than figuring out what is actually going wrong. If you look in the network settings of any device, it's almost always possible to manually change the DNS instead of using the one automatically provided. Out there, google and others run high quality DNS services which are independent of your ISP and free and open for anyone to use. Worth trying those. Most popular two are at 1.1.1.1 and 8.8.8.8
This message was authored by: Paulstaffy1
Mine has been down for several hours now, using up my mobile data! Sll the lights on router are on but connected without Internet on all my devices....
Nothing from sky to let me know after all the time it's been off?
This message was authored by: Daphney91
Wifi issues
for the past few days I have had multiple issues with my Internet and many times before that for the past 2 months that my devices have failed to connect with my Internet it was working fine today for few hours and now for the past 3 hours I haven't had any Internet at all I have reset/rebooted the hub and nothing had worked or resolved this any time I try to check via the app I get a sorry error message with it saying failed to load page I seriously am not happy that I'm paying for a service that I'm having nothing but problems and back to back issues of a service I'm not fully being able to use yet I'm paying alot of money for to which I'm not get a full service from!!
The internet just turned to green but still no internet
Locked
