2
This discussion topic is read only This discussion topic has been answered Discussion topic: Ax88u and Sky Miniboxes
This message was authored by: Vealie28
Hi all,
I've just bought an ASUS AX88U after hearing recommendations here and I'm very excited for it to arrive (tomorrow). I appreciate the set up has been discussed quite a bit in other posts so I'll follow those and hopefully all will be well!
My question however is will I have any trouble connecting my sky mini boxes after removing and replacing the original sky router? Do I have to change any settings to get these to work ok or will the Sky Q main box connected via Ethernet to the AX88U router do the trick?
For info I am on Sky Ultrafast 500Mbps package with Sky Q and three mini boxes around the house.
Thanks!
Avatar for Vealie28
This message was authored by: Vealie28 Answer
Re: Ax88u and Sky Miniboxes
Just as an update - I installed the Ax88u today and its totally transformed my internet experience. Ive gone from around 80Mbps in the backroom to 280Mbps now (over 517Mbps next to the router!!). Having flexibility in the router settings too makes life so much better - Ill never stick with the ISP standard router again.
Locked
Avatar for Vealie28
Avatar for Vealie28
Oh and miniboxes worked just fine
Locked
