This discussion topic is read only Discussion topic: All recordings have disappeared, can’t record or rewind
This message was authored by: Timelord1963
All my recordings have disappeared, can't record, rewind or fast forward. Don't know if there was any update but standby light was on when I returned home. Tried rebooting hasn't worked. Is there anything I can do or have lost my recordings?
Locked
Re: All recordings have disappeared, can’t record or rewind
@Timelord1963
I would have thought that suggests a critical failure: maybe the hard drive.  If completely resetting by removing and replacing the power supply doesn't change anything, you'll need to book a swap-out.
@Timelord1963 there is a system recovery procedure here if thst doesnt work then the hard disc in your box has failed and the box needs replacing.
Locked
