Discussion topic: Wiring outside and damaged box which Sky piggy banked off. Wire comes into housethen outside to dish
This message was authored by lb2014 This message was authored by: lb2014
Re: Wiring outside and damaged box which Sky piggy banked off. Wire comes into housethen outside to
@lb2014  You'll need to be more clear and provide full details of the issue as it looks like you tried to type it all in the character limited subject bar rather than in the message body where you included the pictures.
This message was authored by Mark39 This message was authored by: Mark39
Can you pinpoint where we should looking, please?
lb2014
Oh thank you
box outside lost front wires exposed. Sky piggy banked off box. White wires into house, black upside, across roof to dish.
  • Do I need all these wires and what sbout the damaged box?
This message was authored by Derek_Trotter This message was authored by: Derek_Trotter
@lb2014 wrote:
Oh thank you
Looking at those pictures it appears that only the white twin shotgun cable is connected to the LNB on the dish and it then goes down the house and into your house. These should be the only ones necessary to connect to your Q box. (Assuming you have Sky Q)
If the black wires are connected to the LNB too then it's possible you have a hybrid LNB and the black wires might be for a second Freesat box or TV? Do you have either?
lb2014
Contacting Sky
How do we contact Sky? Chat & phone calls don't work as my question is not included in the options
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: Contacting Sky
@lb2014
What's your question? Perhaps we can save you a call?
▪️I AM NOT A SKY EMPLOYEE ▪️
lb2014
Re: Contacting Sky
It relates to outdoor wiring & damaged box that Sky piggybacked off
Re: Contacting Sky
@lb2014
No need for a new thread. I've moved it into your original thread and removed my post as being the answer.
Re: Contacting Sky
@lb2014 I'm a bit confused, to be honest. It doesn't look like the work of a Sky engineer. Firstly it's not recommended to sling the cable over the roof untethered because it will move about and chafe allowing water to get in. And piggy backing off the same LNB port won't work as the control signals from your Sky boxes will conflict. Each Sky box connection must have a separate cable to a spare port on the LNB.
lb2014
How do I add a photo as doesn't seem to be working. Clicked and photo etc but not loading
On average, new discussions are replied to by our users within 5 hours
