31 May 2023 08:22 PM
I have an AVTEX TV and it states that you can use a common interface module for you sky card, I believe that it might cost extra, but if you have a system that works without carting your sky box around then that would be good
31 May 2023 08:27 PM - last edited: 31 May 2023 09:14 PM
No, Sky do not use these in the UK market, you need to use their equipment to recieve encrypted channels, either Sky Q or Stream.
31 May 2023 09:59 PM
SKY has always been very protective over it's encryption & gone out of its way to avoid CAMs
BTW we should also point out that SKY boxes should also only be used at the registered address & not used elsewhere - the SKY Go app is for use when away
On average, new discussions are replied to by our users within 5 hours
