30 Jun 2023 11:46 AM
Also have sky landline and that doesn't work to make any calls!! I NEED to get in contact with my doctors surgery asap
30 Jun 2023 12:43 PM
Posted by a Superuser, not a Sky employee. Find out moreThe mobile issue has apparently been fixed. Try switching your mobile off and back on again.
30 Jun 2023 07:05 PM
I had the same problem. Spoke to Sky and its a fault between the exchange and my house
30 Jun 2023 08:14 PM
I have the same issue can make or recieved calls on my landline and cannot get through to sky been on the phone for an hour just music
30 Jun 2023 08:32 PM
@daz89 someone on here put me in touch with a sky representative. It took two hours of chatting then waiting but worth it. There is an engineer calling next week. A fault between the exchange and and my phone line. I had a dial tone but just got a message saying number not recognised.
01 Jul 2023 10:08 AM
My landline has been dead for 2 days now. No dial tone
If I ring it from another phone it says the number does not exist
01 Jul 2023 10:15 AM
Posted by a Superuser, not a Sky employee. Find out moreSee if you can run this line test to see if a fault is found outside of your property and if something is found you can book an engineer repair, ignore the fact it says it will test your broadband:
You can also run this test via the MySky app.
Let us know how you get on.
01 Jul 2023 07:08 PM
01 Jul 2023 07:14 PM
@gab64 I had the same trouble. Sky said it was a fault between the exchange and my line. Been fixed now, thanks to someone on here escalating the problem. I was on line with someone from Sky. I got the dial sound but when I rang from my mobile it said Number not recognised. OK now.
01 Jul 2023 07:39 PM
cant call on my mobile because it is unregisters.
paid for sky glass and got bad service
01 Jul 2023 07:44 PM
Posted by a Superuser, not a Sky employee. Find out moreWhat was the result of the line test ?
02 Jul 2023 08:23 AM
02 Jul 2023 08:32 AM
@gab64 wrote:
What line test ?
The line test you were asked to perform in post 7 above.
02 Jul 2023 08:33 AM
@gab64 wrote:
What line test ?
Phone still down - 3 days now
Did you not read @caesarome's reply to your first post? It contains a link to the connection test. That's the first thing to try.
02 Jul 2023 02:57 PM
I clicked the link and its shows the broadband side of things all work fine.
We had an upgrade to our Sky hub on 29/06/2023 - since then landline has been dead.
Phoning the landline number from another phone says the number does not exist.
I bought a new landline phone thinking that was the problem.
But no - still no landline service.
On average, new discussions are replied to by our users within 80 minutes
