Discussion topic: Landline problem
This message was authored by Radpm2 This message was authored by: Radpm2
Landline problem
  • I can make landline calls but cant recieve calls. Ive replaced the handsets and cables but its still the same.
  • Any ideas 💡
Re: Landline problem
@Radpm2
See if you can run this line test to see if a fault is found outside of your property and if something is found you can book an engineer repair, ignore the fact it says it will test your broadband:
https://www.sky.com/help/home/sky-talk/fix-problems-with-my-phone/articles/fix-phone-problems-start
You can also run this test via the MySky app.
Let us know how you get on.
On average, new discussions are replied to by our users within 80 minutes
