5
Discussion topic: no satalite signal
This message was authored by Melgas This message was authored by: Melgas
no satalite signal
i have 3 boxes two are worki g fine butt the third is saying Your Sky Hd Box is not getting a satalite signal.
i have swapped boxes and done all the checks to cabling and done all which i was asked to do online, I am i still getting the same messsge.
This message was authored by Annie+UK This message was authored by: Annie+UK Answer
Re: no satalite signal
Phone Sky or a 3rd party satellite installer to get someone out and they will be able to identify the cause of your issue
This message was authored by Miss+Karen+Blakek This message was authored by: Miss+Karen+Blakek
I haven't been able to watch t.v since ave got it fixed it keeps saying no satellite ave done everything youse have told me
See my answer above
This message was authored by mozt0008 This message was authored by: mozt0008
My Son had this problem "NO SATTELITE SIGNAL IS BEING RECEIVED" with only his SKY PLUS  box,it turned out to be bad cable,which he changed..
Try the same box on a connection you knw works.
EG...He tried his on the one in my room and then tried my SKy plus box in his room.
HIs work fine in my room and mine showed "NO SATELLITE SIGNAL IS BEING RECEIVED" ,so this then confirmed the actual cable was bad and not the connection or LNB on the dish.
I Hope this is of somme help?
Thanks very much
On average, new discussions are replied to by our users within 100 minutes
