18 Apr 2023 03:00 PM
I have an original sky box. After a powercut some of my sky channels are not working A warning stating that no satellite signal is being received. Can anyone help me please.
18 Apr 2023 03:43 PM
Posted by a Superuser, not a Sky employee. Find out moreTurn your box off at the mains for at least five minutes before powering it on again
18 Apr 2023 03:03 PM
What are your Signal Strengths/Qualities? Take a look at the link below:
18 Apr 2023 03:15 PM
System signal & qualities very good but i have an original sky box which for rest of sky is working ok.
18 Apr 2023 03:23 PM
Posted by a Superuser, not a Sky employee. Find out moreStrange that the signal strength is ok whilst the box is reporting no signal 😕
Are you tuning to an affected channel when checking the signal in the settings?
18 Apr 2023 03:41 PM
Yes the settings are the same on effected channels.
18 Apr 2023 04:52 PM
Done that several times leaving it unplugged for over 30mins last couple of times.
18 Apr 2023 05:04 PM
To confirm - is the white part of all four bars at least half way across?
18 Apr 2023 05:08 PM
My FAQ makes it quite clear about that and also has a Graphical example 🙂 So they should know what to look for 😉
19 Apr 2023 03:28 AM
Not sure what you mean. If its the signal strength then it all the way across.
19 Apr 2023 03:38 AM
I also only have plain old sky - no + or hd or glass or Q.
Just plain old sky & an original box.
19 Apr 2023 05:36 PM - last edited: 19 Apr 2023 05:38 PM
If it's a really old Sky Digibox from the 2000s, it's likely to be on the way out.. No Signal (even when there was a signal) used to be a common sign of a failing power supply on these boxes. As it happened after a power cut that seems especially likely to be the cause.
On average, new discussions are replied to by our users within 100 minutes
