Discussion topic: Sky not working - says no signal
This message was authored by Nrwin This message was authored by: Nrwin
My sky hasn't been working for several days. Says the issues is no signal being received.  Not sure if the issue is with the dish or the sky unit
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: Sky not working - says no signal
@Nrwin
No signal normally comes from your TV, no satellite signal normally refers to your Sky box. Have a look at this link
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
If that doesn’t help you, at the end of the link it should give you an option to arrange an engineer to check your dish alignment.
▪️I AM NOT A SKY EMPLOYEE ▪️
This message was authored by Mark39 This message was authored by: Mark39
It could be an issue with the dish, the LNB (on the arm of the dish), the cables, or the connections. It's less likely to be a problem with your Sky box, but not impossible.
On average, new discussions are replied to by our users within 100 minutes
