3
Discussion topic: Sky+ box not working after sky q
This message was authored by KDavies9827 This message was authored by: KDavies9827
Plugged old box back in sky+ after sending sky q box back but I’m just getting mini tv no satellite signal and box is still initialising but it’s been like this for a while now. Could it be the new wifi box causing this? Should I plug the old wifi box back in?
This message was authored by Annie+UK This message was authored by: Annie+UK Answer
Re: Sky+ box not working after sky q
Sky update the disges LNB when Sky Q is installed this is incompatible with Sky+
KDavies9827
Oh no so I won't be able to use my previous box? I was only hoping to use it for the free channels
This message was authored by Mark39 This message was authored by: Mark39
You can if you get a local satellite installer to change the LNB for one compatible with Sky+, or probably better a hybrid LNB which serves both Sky+ and Sky Q.
On average, new discussions are replied to by our users within 100 minutes
