31 Aug 2023 10:31 AM
Sky remote just stopped working - no red light and does not have any effect on the Sky box. It's not the batteries or the remote as we have replaced both. Rebooted the Sky Box, tried all the hacks like holding various buttons down and nothing. It is like the box has stopped recognising the remote (any remote). Can turn box on with the buttons on the box but actions are limited.
Any suggestions? When I tried to get help via Sky, the messages back were eithe upgrade to Sky Q (!) or get an engineer, but then it wouldn't let me book an engineer as I don't have sky Q!
Anyone know how you book an engineer for Sky +?
31 Aug 2023 10:58 AM - last edited: 31 Aug 2023 10:58 AM
Posted by a Superuser, not a Sky employee. Find out moreHave you power cycled your Sky box at the main plug?
31 Aug 2023 11:14 AM
Yes, tried this twice.
31 Aug 2023 11:16 AM
Posted by a Superuser, not a Sky employee. Find out moreDoes the red LED on the remote light up when you press a button?
31 Aug 2023 05:33 PM
No. No lights on either remote and nothing changing on box when remite pressed.
31 Aug 2023 06:04 PM
Posted by a Superuser, not a Sky employee. Find out moreIf the LED on the remote does not light up then this would mean a signal is not being set to the Sky box, strange that multiple remote are not functioning, I'd check the batteries are inserted correctly
31 Aug 2023 06:16 PM
Thanks, but batteries is a basic and rhat is not the problem!
31 Aug 2023 06:19 PM
Posted by a Superuser, not a Sky employee. Find out moreIf you are discribing the issue correctly, you have multiple fault remote controls (which I find odd but not totally impossible)
31 Aug 2023 07:47 PM
Posted by a Superuser, not a Sky employee. Find out moreI agree with @Annie+UK . If the LED in the end of both remotes isn't lighting up when you press one of the buttons, then coincidence as it may be, both remotes are faulty.
On average, new discussions are replied to by our users within 100 minutes
