Discussion topic: Sky + HD box will not connect to internet now fibre broadband has been connected to the property
This message was authored by LB2906 This message was authored by: LB2906
Sky + hd box had no signal now fibre broadband has been connected to the property
This message was authored by Mark39 This message was authored by: Mark39
Re: Sky + HD box will not connect to internet now fibre broadband has been connected to the property
Is that no signal, or no satellite signal? Neither has anything to do with your new fibre connection.
This message was authored by Annie+UK This message was authored by: Annie+UK
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
On average, new discussions are replied to by our users within 100 minutes
