09 Sep 2022 09:56 AM
Have had box as described for many years with no problems at all ... however some 2/3 weeks ago the green "in use" light on front of box has ceased to light during use .... have re-booted box 2 or 3 times, without success, to try to "light" it ... all other lights are operating and there are no function problems at all ... is this simply a bulb gone which can be replaced ???... or something of no consequence .... or more serious requiring attention ??
09 Sep 2022 10:04 AM
Posted by a Superuser, not a Sky employee. Find out moreIf the box is otherwise working normally, I'd ignore it. It's probably, as you posted, a failed LED. Replacing the LED isn't something that a Sky engineer would do (it's not as straightforward as replacing a blown bulb) so the box would need to be replaced in order to fix it.
09 Sep 2022 10:33 AM
Thanks for that... looks like I guessed right !
On average, new discussions are replied to by our users within 100 minutes
