23 Apr 2022 03:36 PM
Have a 2TB Sky + HD box since February 2014. With multitude of recordings.
Recently having a problem with Recordings and their play back.
Watching live is fine, no problem.
Recordings and their Play Back - A number of seemingly random problems:
(i) For some recordings, even though recording red light is on, when finished it shows Failed Technical Fault – 10 (0), or similar. Cannot play it back.
(ii) Even when recording is seemingly OK, when playing back, it freezes, sometimes multiple times. Fast forwarding sometimes moves it on to play again. But other times have to go back and enter later play times. Can subsequently re-freeze.
Is there anything I can do to address these problems, without losing current (many!) recordings?
Some years ago had to do a complete system reset to deal with Diskless Mode problem, losing all recordings in the process.
If I have to do a complete system reset again, does this in effect “reformat” the Sky box hard disk and set aside any bad corrupted disk sectors?
Thank you very much for your guidance.
23 Apr 2022 03:42 PM
Posted by a Superuser, not a Sky employee. Find out moreSounds to me that the HDD is failing and the best fix is to totally replace the box or upgrade to Sky Q
23 Apr 2022 04:48 PM
Thanks Annie.
You say “totally replace the box or upgrade to Sky Q”.
Can it be replaced with another Sky+ box?
Or is the only available box nowadays a Sky Q one?
I still have the old Sky+ HD box that was replaced (for extra capacity & not due to a fault) in 2014. Has a capacity of a couple hundred MBs.
As a stop-gap, can that older box be substituted for my current faulty one?
Is this something I can do myself, without the need for a Sky Engineer?
By just transferring the Viewing Card from current box to the other?
Thanks again.
23 Apr 2022 05:00 PM
Posted by a Superuser, not a Sky employee. Find out moreYou can replace your box for any Sky+ box that is compatible with your dishes LNB, see my Sky+ FAQ for instructions on how to pair your viewing card to the replacement box
23 Apr 2022 06:46 PM
Thanks Annie.
I found it under Q 21. How do you perform a New Install?
23 Apr 2022 06:55 PM
Posted by a Superuser, not a Sky employee. Find out more@MichaelBere For a new install press services on remote key in 001 and press select in very quick succession that should bring up the engineer menu scroll across to new install
23 Apr 2022 08:35 PM
SKY1992bf Thanks for that.
Will try alternate box as soon as I get a chance.
24 Apr 2022 02:46 PM
Hello again.
Another related query please.
Analogous to a Laptop HDD, is it possible to reformat the HDD in my current 2 TB box (accepting that all recordings would be lost in the process)?
With the objective of getting the box working satisfactorily again, after possibly setting aside any bad/corrupt sectors in the HDD to prevent recording over them?
Thanks & we appreciate your advice.
24 Apr 2022 02:57 PM
Posted by a Superuser, not a Sky employee. Find out more@MichaelBere a system reset affectively does that. Obviously you'll lose all your current recordings. The option is in the same menu as @SKY1992bf mentioned. It might restore normal working, but possibly only temporarily if the disk is on its way out.
24 Apr 2022 05:37 PM
That's grand. Thanks Mark39
25 Apr 2022 12:53 PM
Bear in mind the hard drive is at least 8 years old, so is already probably past the designed lifetime and so stands a good chance of failing soon.
25 Apr 2022 06:08 PM
Yes rscott, it's probably only a matter of time before that happens.
Will see how we get on!
Thnaks again.
08 Jan 2024 07:04 PM
Can I have a number to call please
08 Jan 2024 07:45 PM
You can find the number (the forum disallows posting them) via the 'need more help' link here: https://www.sky.com/help/home
Or can the Community here help?
Bear in mind that Sky no longer replace Sky+ boxes, and don't provide engineer support for them unless you have Sky Protect.
On average, new discussions are replied to by our users within 100 minutes
