Discussion topic: No version in sky plus remote unable to programme volume
This message was authored by JayBee32 This message was authored by: JayBee32
Unable to programme sky+ remote volume. No version number inside. Have new Samsung Neo QLED QN90C and need code too.
This message was authored by Mark39 This message was authored by: Mark39
Re: No version in sky plus remote unable to programme volume
Most likely a Rev9 or Rev10, unless it's very old. You could try the codes for both. If there's a code known to work with your TV model it will be listed here: https://www.sky.com/help/program-your-remote
This message was authored by Annie+UK This message was authored by: Annie+UK
How to program your remote control with no code and/or remote version number.
Take a look at the link below:
See question Q43 in my Sky Plus F⋅A⋅Q
This message was authored by Exiled-in-HH This message was authored by: Exiled-in-HH
Does that TV support IR remotes or just Bluetooth remotes?
Exiled in HH
JayBee32
I believe it's both types, IR and Bluetooth. I did read somewhere that Sky are no longer supporting Sky+ and looks like they have removed the ability to do anything with the remote in the Help section on the Sky+ box too, kept taking me around in circles. Looks like they might be trying to force people to move to Q or Glass!
JayBee32
Thanks Annie will give that a try! Thanks all for your help.
@JayBee32 wrote:
I believe it's both types, IR and Bluetooth. I did read somewhere that Sky are no longer supporting Sky+ and looks like they have removed the ability to do anything with the remote ....
Short of physically taking away everyone's Sky+ remote, I can't see how that would be possible.
This message was authored by xenon81 This message was authored by: xenon81
The full message said "they have removed the ability to do anything with the remote in the Help section" and that's right, the various interactive/help sections including the one for finding remote codes have been removed from Sky+HD recently.
This still works?
Ah..I've twigged (I blame the cold weather) yes, the interactive functionality on Sky+HD boxes has indeed been removed. Apologies, I misunderstood.
On average, new discussions are replied to by our users within 100 minutes
