06 Jan 2021 08:22 PM
When pressing the record button nothing happens. Live pause and rewind still works. When the delete button is pressed it says deleting but nothing happens.
Posted by a Superuser, not a Sky employee. Find out moreTry a planner rebuild:
Press Services on your remote
Select Help
Select Sky+ Rebuild
This should take no longer than 10 minutes, don't do it if you are recording or due to start recording something.
Select Help
Select Sky+ Rebuild
07 Jan 2021 09:39 PM
Thank you VERY much! My 'record' button wouldn't work. Your suggestion solved the problem. Saved me a lot of hassle. Very grateful.
11 Sep 2022 02:21 PM
Hi had problems deleting recordings pressed delete nothing happened so turned powered off for 30 seconds restarted box and recordings started deleting
On average, new discussions are replied to by our users within 100 minutes
