05 Apr 2022 09:44 AM
Hello
I have a Sky +hd decorder with Quad LND on the dish. Can I replace a Quad LNB which is future proof for 4K for future SkyQ decoder if I have to replace the decoder in future and HD for present decoder.
Many thanks for your help
Cass
05 Apr 2022 09:49 AM
Posted by a Superuser, not a Sky employee. Find out moreThere is no reason to future proof your LNB for Sky Q as Sky will change the LNB when/if you upgrade your service to Q
05 Apr 2022 12:52 PM
Hello Annie
Thanks for your response,so I am on the understanding that you cannot buy a universal Quad LNB which will work on sky Q decorder as well as on the Sky+ HD decorder. These information is for anybody who do not subscribe to sky hence the question thats all.
Many thanks
Cass
05 Apr 2022 12:55 PM
Posted by a Superuser, not a Sky employee. Find out more@carson Anyone can buy a hybrid LNB for use with Sky Q and Sky+ or older Freesat boxes.
05 Apr 2022 01:30 PM - last edited: 05 Apr 2022 03:06 PM
As @Annie+UK indicates, the current EL027 Q-compatible 'hybrid' quad-LNB is widely available online for £20-£30. You'll also find some stock of the original 'hybrid' hex-LNB (EL010 and EL028).
13 Apr 2023 03:21 PM
Do you need an engineer to replace the lnb
13 Apr 2023 03:26 PM
Anyone can change an LNB as long as you know how to set it up to get the best signal from it (usually requiring special equipment for the signal strength)
13 Apr 2023 03:45 PM - last edited: 13 Apr 2023 03:48 PM
It's viable for DIY as long as dish alignment isn't shifted in the process (and, of course, if access is safe)
Worth noting that the LNB arm on older dishes isn't necessarily compatible with recent LNB models.
On average, new discussions are replied to by our users within 100 minutes
