05 Sep 2022 06:09 PM
Hi. I Have Sky HD at home.
Everytime it rains heavyish, I lose all channels, or at best, there's very pixelated images and intermittent sound.
My dish is nearly years old, so has likely had it's life.
My problem is, for some time, I can't be at home for an engineer to call, even on weekends (my work hours are all over the place, with little notice)
After repair or replacement, would they need access to the house to check the signal is ok?
p.s.
I don't want a Sky Q upgrade right now.
Thank you.
05 Sep 2022 06:14 PM
The dish is nearly 20 years old. I missed bits out 🙂
05 Sep 2022 06:58 PM
Posted by a Superuser, not a Sky employee. Find out moreThey would normally check the signal has improved, plus if the engineer feels the need to move the dish position he/she would require your okay.
05 Sep 2022 10:54 PM
Daniel0120
I don't mind the dish being moved, but do you mean he'd need to enter the house to check the signal?
06 Sep 2022 05:27 AM
Posted by a Superuser, not a Sky employee. Find out moreYes. Surely you want the engineer to check the pixels and sound issues have been fixed.
06 Sep 2022 09:38 AM - last edited: 06 Sep 2022 09:51 AM
Posted by a Superuser, not a Sky employee. Find out moreThe engineer will use a satellite direction finder and signal meter to align the dish externally but as @Daniel0210 indicates they will also want to check cable signal at the Sky box. They typically also require someone to be available to give permission for them to drill a hole for their ladder safety tether.
On average, new discussions are replied to by our users within 100 minutes
