28 Mar 2024 08:17 PM
I have a 150mbps full fibre connection from a company called Zzoomm. As it enters my home, there is a separate modem and then a powerful router which actually gives about 190 mbps in every room.
If I wanted to purchase Sky stream, would I need the small square sky box or just the pucks working solely from wifi and with no Ethernet cables?
28 Mar 2024 08:25 PM
Posted by a Superuser, not a Sky employee. Find out moreIt should work perfectly fine using WIFI.
Its just some customers find a better experience using an ethernet cable due to local interference causing a weaker and unstable Wifi connection.
Sky Stream user. Former Sky+ HD and Sky Broadband customer
NOT a Sky Employee
NOT a Sky Employee
28 Mar 2024 09:05 PM
Just the Puck as Stream should work on any internet connection that meets the required specs
29 Mar 2024 08:08 AM
That's great guys. Thank you for your help
