06 Jan 2024 10:04 AM
Hi,
How do I go about getting a replacement remote for my Sky Stream Puk, have had no luck in getting through to a call centre with a human being that can assist me, am unable to use my service.
Thanks,
06 Jan 2024 10:27 AM
Posted by a Superuser, not a Sky employee. Find out moreIf the remote has broken there are a couple of things you can try as a temp solution to see if you can getting working whilst waiting your replacement:
Check the batteries
An easy way to check is to cover the buttons slightly on your Sky remote with your hand. You should see a white backlight behind the buttons. If you don't see the backlight the issue is the power with the remote, so potentially a battery issue.
Check the battery compartment to make sure the paper used to protect the battery has been fully removed. It might have ripped when being removed leaving some behind.
Still can't see the backlight? It’s likely you need to replace the two AAA batteries.
Pair the remote
Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
Press 1 and 3 together for three seconds (bluetooth mode) and follow any on-screen instructions.
The next option sounds insane but a number of users have reported it resolving the issue with their remotes. You could try holding the remote at both ends and giving it a gentle twist as though you were wringing out a towel.
If none of these options work you can request a replacement remote via this link: https://www.sky.com/help/forms/streaming-tv-remote
If you have an old Sky Q remote, you can use that as an interim solution whilst you await the new remote.
Sky Stream user. Former Sky+ HD and Sky Broadband customer
NOT a Sky Employee
29 Mar 2024 10:31 AM
I need a replacement handset as it is not working anymore what do I need to do to get one ?
29 Mar 2024 10:36 AM
Posted by a Superuser, not a Sky employee. Find out more@Mel60 Read the post directly above yours as there is a link you can use.
