Discussion topic: Sky q wont turn on No power light
This message was authored by Adams1231 This message was authored by: Adams1231
as if the box is broken
This message was authored by ThePope27 This message was authored by: ThePope27
Re: Sky q wont turn on No power light
Hi @Adams1231,
Does it have an external power supply, or does it have a blue figure of 8 connector going in the back of the box (internal power supply)?
If it's the latter do you have a spare figure of 8 cable that you can test it with ?
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Adams1231
Hi solid red dot
won't do anything else
Hi @Adams1231
Please try this
To complete the recovery procedure on your main Sky Q box:
  1. Switch the Sky Q box off at the mains.
  2. Hold down the standby button on the front of the box, then switch it back on at the mains.
  3. Keep the standby button held down until you see alternating red and amber lights on the front of the box. This will start a software update.
Please note
  1. The update can take up to 15 minutes, then the box will turn off and go back to a single red light.
  2. Your box will restart.
  3. After the on screen messages have disappeared, press Home on your Sky Q remote to switch your box back on.
If the screen freezes on Updating software Step 1 of 2 or Step 2 of 2 instead of going to the start up screens as expected:
  1. Switch the box off at the mains, then back on.
  2. When you see the hello start up screen hold in the standby button on the box, and you should see Updating software step 2 of 2.
