Discussion topic: Sky box isn't working, it freezes when trying to change channels
This message was authored by Sausage101 This message was authored by: Sausage101
My sky isnt working and freezes when I try to change channels
Re: Sky box isn't working, it freezes when trying to change channels
Hi @Sausage101
Try a Reset Settings in the main Q box hidden menu.
