27 Jan 2024 08:42 PM
sky a mini box showing message to check subscription
tv working fine on main box but no channels on mini box working just showing message
27 Jan 2024 08:44 PM
Hi @Auldhand
Reboot the mini as above.
28 Jan 2024 12:14 PM
@oldfella Didn't work unfortunately
28 Jan 2024 12:17 PM
Hi @Auldhand
Try a Reset Settings in the main Q box hidden menu.
(Resetting the settings will also reset:
Settings changed within the hidden engineer menu, include LNB type. If on a communal dish you need to reset the LNB to SCR in the hidden menu. After changing the LNB type you need to reboot the Q box.)
Once the main Q box is back and fully running reboot the mini again.
