Discussion topic: Sky Q Apps and others have disappeared and nothing worked.
nad1611
This message was authored by nad1611 This message was authored by: nad1611
Re: Sky Q Apps and others have disappeared and nothing worked.
Ok. Thanks.  I'll try now and come back.
nad1611
Should it be asking me to press and hold the WPS button after selecting the Wired option ?
No @nad1611
It may ask but don't press any WPS buttons.
Just wait to see if it connects after selecting connect wired.
nad1611
So it has asked but if not showing as "obtaining  IP address ". I'm presuming if we have a VPN then that will be unsuccessful?
Yes, has now said No IP adresss obtained.
Not sure what happens if you have a VPN @nad1611
nad1611
Ok. Will do some research. Thanks for your help.
Hi @nad1611
Main thing when connecting by Ethernet is to carry out a Network reset (with the Ethernet connected) and do not carry out any WPS.
This helps to force the Q box to use the Ethernet.
