Discussion topic: No sky channels
This message was authored by Carol1957 This message was authored by: Carol1957
No sky channels
Unable to receive any Sky channels. Internet perfect
This message was authored by Mark39 This message was authored by: Mark39
Re: No sky channels
Which Tv platform? Sky Q? Sky+? Sky Stream? Error message?
Carol1957
Re: No sky channels
Hi Mark
It's Sky Q
Thank you
Re: No sky channels
Thanks.  I've moved your post to the Siy Q forum. Can you tell us more about a what's happening when you try to tune to a channel? Is there an on screen message? Are any channels working?
Re: No sky channels
Hi @Carol1957
Have you tried rebooting your Q box?
Carol1957
Re: No sky channels
Hi Mark
Can get all normal channels but nothing else, no catch up TV no recordings just get the same message No Internet connection
Re: No sky channels
Hi @Carol1957
If on Sky broadband first reset your broadband router by holding Reset on the back until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
Carol1957
Re: No sky channels
Evening Oldfella
Not tried anything as yet, forgive my stupidity, which is the Standby button on the remote 😊
Re: No sky channels
@Carol1957 wrote:
Evening Oldfella
Power button top left @Carol1957
Carol1957
Re: No sky channels
Hi Oldfella
Got so far, no WPS button on the router 😕
Carol1957
Re: No sky channels
Hello,
Doesn't seem to be working, got as far as pressing the Amber led on the Q box. No WPS button on the back of the router😕
Re: No sky channels
@Carol1957 wrote:
Hello,
Hi @Carol1957
All routers will have a WPS button.
Carol1957
Re: No sky channels
Morning Oldfella
Thank you so much, instructions on TV said that button was on the back 🙄
It's all sorted now, I'm back up and running
Have a fab day 😁
