17 Jan 2024 10:47 AM
Hi.
when watching tv the screen goes blue with a black line at the top saying "no connection from mini box to sky q box." It happens quite frequently and is really annoying.
17 Jan 2024 12:20 PM
@Donald+Donald+duc wrote:
Hi.
Reboot the mini as above.
