06 Feb 2024 10:24 AM
My Sky mini box remote has recently been replaced as the last one stopped working. The old one controlled the TV as it was synced to it, and I don't have a separate one for the TV.
Whilst the new remote operates the mini box as it goes to green, I've not been able to synced with the TV I'm unable to get the TV to even turn on as I have nothing to do this with.
Help please!!! What do I do in order to be able to operate the TV with the new Sky remote and get everything working.
06 Feb 2024 11:07 AM
@NinaGabrielle wrote:
Thank you @oldfella although I'm confused by this. I can't turn the tv on as mentioned, so how would I see anything onscreen? Will the tv automatically turn on when I press 1 & 3 together until the remote led flashes?
Afraid the TV needs to be on to sync the remote.
What happens if you reboot your TV. ie disconnect the power for 30 secs and then power back on?
Isn't there a manual switch on your TV to switch it on?
06 Feb 2024 10:54 AM
Try completly resetting your new Bluetooth remote.
06 Feb 2024 10:59 AM
06 Feb 2024 11:46 AM
Posted by a Superuser, not a Sky employee. Find out moreEvery TV has a manual on switch even if it's well hidden.
06 Feb 2024 10:32 PM
@oldfella it's times like this I definitely realise I have a brain injury. As if something that basic wasn't my trail of thought?! But thankfully now working due to turning the tv on manually. Much appreciated
