4
Discussion topic: Netlix stopped working
This message was authored by MartynHEN This message was authored by: MartynHEN
Netfix suddenly stopped working  on my bedroom TV although Netlix works fine on my living room TV main Sky Q box and on my iPad over WiFi. Is there a way to reset the upstairs Sky Q mini box please?
MartynHEN
This message was authored by MartynHEN This message was authored by: MartynHEN Answer
Re: Netflix stopped working
Thank you oldfella. I did everything you suggested and I did eventually find a way of getting Netflix back on.
This is what I now have to do and hope someone else will find this useful.
Press home on the Sky Q remote, scroll to on demand, scroll to Netflix, select apps and the logins appear again and all the films are there to choose from. Hooray.
Re: Netlix stopped working
Hi @MartynHEN
Reboot the mini as above.
MartynHEN
I've got a good network connection , all Sky channels on the bedroom TV but no Netfix. It's. asking to rejoin and I've not got the apps that are on my main TV and iPad.
Hi @MartynHEN
All Q boxes and minis should be on the same software version.
See following links for latest Software versions and how to update Q software
https://www.sky.com/help/articles/sky-software-updates
https://www.sky.com/help/articles/updating-sky-box-software
MartynHEN
