19 Jul 2023 11:55 AM
Decorators are working in the room so have to move the skybox to another room. I need help to set up. Thanks
19 Jul 2023 12:03 PM - last edited: 19 Jul 2023 12:03 PM
Is this your main box or a mini ?
If it is your main box then if you really need it on, then probably your best solution woud be to get a long Satellite extension cable (& make sure it is taped down so as not to be a trip hazard)
20 Jul 2023 09:02 PM
No, I don't need a new box. We will revert back to main living room when we finish work. Thank you very much.
20 Jul 2023 11:30 PM - last edited: 20 Jul 2023 11:32 PM
@Agnes+baiden wrote:No, I don't need a new box. We will revert back to main living room when we finish work. Thank you very much.
So the suggestion of getting satellite cable extenders is the temporary solution for you. If you search on a popular online shopping store, you'll be offered lots of different lengths.
