Discussion topic: My tv is glitching and freezing and then sometimes sayin no signal
This message was authored by Dawn83 This message was authored by: Dawn83
The channels glitch, freeze and sometimes says no signal or technical fault
Re: My tv is glitching and freezing and then sometimes sayin no signal
Hi @Dawn83
