Discussion topic: My tv is glitching and freezing and then sometimes sayin no signal
Message posted on 24 Nov 2023 09:46 AM
The channels glitch, freeze and sometimes says no signal or technical fault
Message posted on 24 Nov 2023 10:10 AM
							Re: My tv is glitching and freezing and then sometimes sayin no signal
Hi @Dawn83
