Discussion topic: My sky mini box is now not working
This message was authored by Plumbtrainer This message was authored by: Plumbtrainer
My sky minibox has stopped working. Have tried turning off and turning on again, rebooting router
Re: My sky mini box is now not working
Hi @Plumbtrainer
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Plumbtrainer
Hi
I have tried what you suggested and all I get is something about my router not issueing an IP address. Sorry this oap is losing the wiil to live
Plumbtrainer
Hi@oldfella
I have tried what you have suggested but am now getting a message that my router is not supplying IP addresses
This message was authored by Donald+Taylor This message was authored by: Donald+Taylor
I switched it off and pulled the plugs out for 1 hour. .. OK now. They should not sell faulty equipment. If this was Motor vehicles they would be bankrupt overnight.
