23 Feb 2024 04:38 PM
Despite reading all the other experiences of people having disconnections with their mini boxes, I have tried all the options, at one point I thought it had cured, but now its worse than ever. I am watching TV via a mini box and it will work for a minute then stop for a similar time. I have had these mini boxes for several years now without any problems. The problems started a few weeks ago and I thought that it may have been my internet connection, but I spotted a response to someone else where the answer was that the internet was not actually involved with mini box connection. The messages that I get seem to say that the faults are due to NO internet connection , so why is this ? As it occurs with all three of my mini boxes (the most I use is two at once) I can only conclude that it must be the main Sky box that is at fault. How do I get this seen to ?!
23 Feb 2024 04:54 PM
Posted by a Superuser, not a Sky employee. Find out moreWho provides your internet and how is it setup?
23 Feb 2024 04:57 PM
Hi @BrianJ1949
Reboot the mini as above. Start with the mini nearest to the main Q box.
When you carry out the Network reset on the second mini you can use the first mini for WPS if nearer than the main Q box.
23 Feb 2024 04:58 PM
I use TalkTalk via FTTC at 60 GBS. I have contacted them and they tested the line and said the connection does not have any faults
23 Feb 2024 05:00 PM
Sorry old chap but I've done that last week !
23 Feb 2024 05:17 PM
Posted by a Superuser, not a Sky employee. Find out moreAs a non-Sky ISP then the main box will only connect over 2.4GHz. It's usually best to configure the router with split SSID's.
The Q boxes will use their own 5GHz network on channel 36/80MHz width - you would need to ensure the TT router avoids channels 36 to 48.
Otherwise, perhaps there is a fault...
23 Feb 2024 07:22 PM
I have tried turning off my 5 ghz channel and the Sky boxes are configured to use 2.4ghz. I've tried everything that has been spoken about on Sky Community by others as there have been a lot of similar issues. If this has suddenly become something common, maybe there has been some significant change made by Sky in the software ? I have heard that they are moving towards using the internet to stream programs. I doubt that they would do anything to inhibit satallite users though. I have just reconfigured a repeater box, which itself caused problems when I first had Sky Q. In fact it ran better without the repeater than with it - for several years too !
23 Feb 2024 07:32 PM - last edited: 23 Feb 2024 07:33 PM
Exactly what is your repeater box and how is it positioned and connected @BrianJ1949 ?
23 Feb 2024 07:47 PM
@oldfella It's a Sky device given to me by the installer, it's in the place that she suggested putting it after using her hand held device that works out the best signal path (don't know what it is called) At the moment the mini box that it was meant for it still OK. I haven't tried the other two yet ............
23 Feb 2024 08:00 PM
Hi @BrianJ1949
If it is a Sky Q WiFi booster I assume it is connected by WPS to your main Q box and positioned between the main Q box and the nearest mini. The mini should then be connected following a Network reset and WPS carried out on the booster.
I
23 Feb 2024 11:56 PM
Hi @oldfella Sorry for using the wrong terminology to me its just a box that relays the Wifi signal. It is configured already, they don't lose the previous configuration. At the moment everything is stable, but I will reserve judgement for a day or two.
24 Feb 2024 11:37 PM
Something I noticed to day when the problem occured on Mini Box number 2 was that I could not get the mini box to reconnect at all until I switched the main Sky Q box on (from standby of course) once again this did not need to be done in the past, but it does seem to make the mini box cut out far less. It's still annoying though. I have tried to contact Sky but they only seem to use senseless bots that ask the same question over and over with no means of me saying that the probelm occurs again and again. I am becoming quite competant at resetting the mini boxes communications with the main box .........
